주요 콘텐츠로 건너뛰기
모델 A1502 / 4MB 공유 L3 캐시 2.6 GHz (Turbo Boost 최대 3.1 GHz) 또는 2.8 GHz (Turbo Boost 최대 3.3 GHz) 듀얼-코어 Intel Core i7 프로세서.
473 질문 전체 보기
Temperature of mac vs fan rpm
The fan on my mid 2014 macbook pro retina always seems to be running at around 1300 or so rpm. However, it doesn't seem to go higher even when the system temperature increases.
For example it was once operating at around 71c with only around 1295-1306rpm.
Is this normal operation?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
You raise a good question here on what is the max RPM this systems fan runs upto.
댓글 달기
답변 1개
선택된 해법
The fans can run at 2,200 RMP or more, but it's best not to fool with them manually if at all possible.
If you want to investigate the state of your hardware, connect the MacBook Pro to a charger and use Apple Hardware Test. In case of heat issues, or to generate more heat run the test 2 or 3x in succession.
After starting into Apple Hardware Test, choose your language, mark the option to run an extended test and start the test. If at the end of the test you see an error, run it down.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Agreed! + Using software to over-ride the fan/s only shortens the life of your system. What is important is using the correct hardware and if needed adapter cables so the built-in temperature management system is able to effectively manage the heat generation in real time.
댓글 달기
귀하의 답변을 추가하세요
Will 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 5,130
