주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
526 질문 전체 보기
Purple tint after removing the front glass
Hello, I tried this guide: Samsung Galaxy S4 Cracked Front Glass Replacement
To replace my S4 glass.
I managed to remove the glass, but the screen had a different color in one zone. I was concerned about it, so I tried turning it on, and I found that it that area the screen is purple-ish.
What can I do about it? Do I have to buy the whole assembly to replace everything?
Touchscreen works even in that area, so I guess it's not the digitizer. Maybe something can be done software-wise to balance the wrong color?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
Hi Cero,
Unfortunately, that looks to be some damage to the display caused during glass removal. Very few times does this go away over time and most often then not a new display assembly is required.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
Same issue here. Did you fix it? Was also told it's the "glue" used to replace screen glass and that it will go away eventually???
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
If it really was the glue, cleaning it off the screen should solve the issue then.
Yip, not the glue at all... they clearly damaged the display and the touch is unresponsive in places
댓글 달기
귀하의 답변을 추가하세요
Cero 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 6
전체 시간: 1,189
