주요 콘텐츠로 건너뛰기
Toy quadcopter with camera, controlled over Wifi by smartphone.
23 질문 전체 보기
Trouble shooting a loose wire on my 2.0
Typical signs of a loose wire any rough movement of the drone and I loose the LEDs on the bottom and get them right back. I did some testing right after take of with hard spins and flips normally causing the problem and for it to crash. Any ideas on where to start or a common problem I can't find would be great.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
Well I am not an expert on the topic but if the wires connect on the mother board this should help you gain access to the motherboard to see if the cables are connected and the power supply. Maybe you have a short Mother Board Access
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 6
전체 시간: 364
