주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
best tool for standoff screws - stuck standoff screws
Hi,
Been reading posts on the standoff screws and removal of the screws when looking to remove the logic board.
I have been using a small flat head screw driver to remove these however I have been coming across some extremely tight screws which when using this method, I end up spending a good 30-60 mins removing two screws as the force needed to move them means the flat head driver slips,
Does/has anyone come across this problem at all? is there a tool that people use specifically for these screws? i've read about grinding down a phillips screwdriver to make it flat to get a good ground in all four connections. what do people think?
Thank you
Danny
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 4개
선택된 답변
Here's what you need:
[연계 제품이 누락 또는 비활성화 됨: IF145-343]
해당 답변은 도움이 되었습니까?
점수 5
댓글 2개:
You can also buy a standalone driver with that same tip. I have one and it is lightyears better than using spudgers or flatheads. Its worth the couple of bucks to buy one.
Hey! My standoff hex nut that I am trying to remove in my iPhone 6S is completely smooth! It does not have a slot for a flathead to fit anywhere. Any ideas?
댓글 달기
Those things are extremely aggravating. I don't know why someone hasn't invented a screwdriver just for them
I have found the the round side of a metal spudger works really well when you have plenty of room and the pointed side works ok (better than a flathead screwdriver) in tighter spots.
http://www.mobiledefenders.com/metal-spu...
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
THEY DO! after a lot of digging around i found a screwdriver on ebay from china that is specifically for these stand off screws!! its incredable! best £10 i ever spent!
I worked on one for about 10 minutes with all of the different flat head attachments that come in the fixit kit and could only get it off after seeing this post and using a metal spudger. Thank you!
댓글 달기
If you use a bigger flathead screwdriver, you should get more pressure? Or find a flathead screwdriver with a bigget bit so that it fills up the track in the screw?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I use the standard one you get in most repair kits and it works fine, just position it perfectly
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
danny 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 17
30일 전: 83
전체 시간: 13,081
