주요 콘텐츠로 건너뛰기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
2375 질문 전체 보기
질문 마감됨
Why iPhone 4 will not charge?
My GSM iPhone 4 will not charge. I installed a new battery and all functions work normally except the battery will not charge and drains to zero. I'm using a cable that works properly with my iPad 2. I replaced the dock connector and installed a new battery but this did not fix the problem. Before the new battery fully drained I did a full reset, but this also did not fix the problem. There was not enough battery life to try a software update. I also tried reseting by depressing the home and power buttons until reset. Any suggestions on what else to try? Thanks!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Have you tried another battery?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Yes, the phone will work with a new battery, other than of course it will not charge.
댓글 달기
Hey Mark, due to the fact your iPhone is a mini computer, it makes it a sensitive piece of equipment. Your more then likely having a motherboard related issue. At this point your options are limited.
A.)Take it to a professional shop to have it properly diagnosed.
or
B.) You can try cleaning the motherboard with some 91% alcohol and a toothbrush, very gently do this. Clean the entire thing then dry it thoroughly with a blow dryer if possible. Dust and dirt accumulates after awhile of using these devices (2-3 years).
If that does not help, try known working charge ports and batteries, its possible the ones you tested with were defective.
Other then that, your going to need some professional assistance.
Good luck my friend. Let us know how it works out.
Josh.O
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Many thanks Josh, I will try cleaning per your directions.
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 79
