주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
질문 마감됨
Samsung Galaxy S5 has battery or charging problem
Hello,
I have a problem with my Samsung Galaxy S5 .
The battery runs out very quickly , I bought a new battery, and I still have the same problem. My phone is discharged after 4 or 5 hours , even if I do not use it. Suddenly I realized that the problem is related to the device, and not to the battery; but I have no idea how to fix it.
Thank you in advance for your answers :)
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
1.The first thing to do is make sure that you are using the Samsung charger and cable that came with the S5. Other chargers may have different voltage ratings and they won’t always work with the S5. Give the phone a good 30 minutes plugged in before you try to turn it on.
2.Try changing the wall socket and using the cable and charger on a different device to make sure there are no faults there. Try a different charger and cable with the same rating.
3.Try plugging the S5 into a USB port on your PC or laptop. Bear in mind that it will charge more slowly from a USB port than from the charger plugged into the wall.
4.Take a look at the charging port, blow into it or use compressed air to make sure there’s nothing blocking it.
5.If it still isn’t working then you may have a dead battery or a broken charging port. replace the charging port yourself. Here’s an iFixit guide, but it’s a complex procedure.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,634
