주요 콘텐츠로 건너뛰기
Samsung Galaxy S4 모델 i9505는 13-megapixel 후면 카메라 및 5-inch 1080p 화면이 특징입니다.
526 질문 전체 보기
Replacement screen wont light up when mid frame is fitted
I recently replaced a cracked screen in a friends Galaxy S4. When I first put the phone back together I thought the new screen was faulty as the phone would turn on but the display wouldn't light up. After some fiddling around I tried turning on the phone while I had the mid frame removed and to my surprise the screen worked just fine. Upon re-installing the mid frame the screen stopped working again. I removed the mid frame once more, turned the phone on and then began to snap the display assembly back into the mid frame. Everything was fine until I snapped the display assembly and the mid frame together around the top left corner near the volume button at which point the screen cut out. Does anybody know of a way that the screen could be shorting out? Or could it perhaps be pressure on the digitizer flex cable? Any assistance would be greatly appreciated.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
Hi, did you ever find a solution to this as I have exactly the same problem.
Kind Regards,
Danny.
댓글 달기
답변 2개
I faced the exact same problems with my new brand new s4 module from a official Samsung dealer. I could secure the whole frame, but once i secured the right top part of the midframe (looking from behind) it would short out and not even boot the whole phone anymore.
The phone was a i9506 and the module a i9505.
I am not sure if this has anything to do with it, but i do know what caused it.
When i taped off the black screw securing the motherboard right under the part of the frame that shorts the display the whole problem went away.
I tried it without the black screw and it also does not short out.
I believe the black screw helps alot with positioning accuracy from your GPS, so if it is not a solution to leave out the black screw for good, u will have to kapton tape it.
To make it a little bit more clear, i am talking about this black screw:
Good luck! :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Not sure if this will help. But I had same problem and I then relized I had ordered frames for verizon/Sprint and there just enough difference between them and T-Mobile/AT&T to make it not sit right and it actually power switch causing problem.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tom Burridge 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 4
전체 시간: 476
