주요 콘텐츠로 건너뛰기
Samsung Galaxy S3는 안구-추적 기능, 늘어난 저장 용량 및 무선 충전 옵션을 갖춘 멀티-터치, 슬레이트-형식 스마트폰입니다.
459 질문 전체 보기
display brightness not increasing or decreasing
I have a samsung galaxy s3 i9300. Its screen got cracked so gave it to a local repairer.he replaced the whole display and touch.the touch is working fine but now the display brightness is neither increasing nor decreasing. So my question is.is there any problem in display?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 12
댓글 1개
sir mera samsung j5 ki brightness work nehi kar rahi ha ji kya karu ma plz.. mare problem ko solve karo ji
댓글 달기
답변 10개
가장 유용한 답변
The replacement screen u got is an lcd whereas the original one is an led.thats why the brightness cannot be controlled
해당 답변은 도움이 되었습니까?
점수 7
댓글 2개:
but there aren't a solutions for brightness check with an led display?
I would have believed this until I used a 3rd party app to check control brightness, that worked perfectly fine. I would try a phone reset but right now using the app.
댓글 달기
Hi Nitish,
Are you sure auto-brightness is not activated?
Perhaps energy saving is enabled?
To test everything with your screen i suggest you launch the test menu and see if everything works there, there is a special button called "dimming" there to test as such;
-> go to your "keypad" (as if you want to call somebody)
-> Type in: *#0*#
It should start the test menu instantly.
Let us know what the tests do :)
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
In dimming test it showing three colours. Red,blue and green. Nothing else is happening
댓글 달기
go to play stor install apk name NIGHT MODE it can be easly fixed
ukrain rx
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
If you have replaced your display folder then sometimes you face this problem , because of cheap quality display folder .
For this you have to download night mode application from play store .It will work for you.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
Reset your device and off the auto power saving and try again
I think its work unless there is a hardware problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If you have changed your phone display then it might create problem because some china display doesn't have the hardware that support display brightness. If not so then try factory data reset this might work.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Yes bro u are right? This happens to me also,it is only because shop owner replace not the original folder infact any third class , cheaper folder?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
My mobile brightness not increase problem samsung j7
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
First check the auto brightness option,This is the symbol of copy Lcd only to display the graphic not controlled light system and phone also goes to heating up problem better to change original OLED LCD.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
brightness not working samung c7000
Update (09/17/2019)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
nitish tokas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 25
전체 시간: 43,038
