주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
질문 마감됨
Won't Charge after keyboard replacement
I replaced the Keyboard on Macbook Pro 2011 13"
After re-assembly it will not charge. The Battery dead, the LED will not show on any charger, and it will not charge.
What could be causing this? Please please please help!
Thank you
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
check if your magsafe DCin board is well connected to the logic board socket.
댓글 달기
답변 1개
선택된 답변
Go over all your connections(ors) again. 99% of the time a connection that appears correct or good is not completely seated or locked down.
The other cause could be the reason you replaced the keyboard - liquid spill? - may have caused damage to the logic board or components. Go over the board with a magnifier looking for corrosion (discoloration) or burn marks/swollen components.
If this answer is acceptable please remember to return and mark it accepted.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 693
