주요 콘텐츠로 건너뛰기
2.2, 2.4, 2.5, 또는 2.6 GHz Core 2 Duo 프로세서
759 질문 전체 보기
Why is the Nvidia gpu failing?
I usually get Nvidia gpu card pblm in my mac as a result of which it doesnt bootup even if it is powered on....so I have to reflow the gpu when i get this pblm......is there is any way to fix this problem permanently?????? please help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
The problem is two fold:
  • NVIDIA had a bad run of GPU chips which Apple did offer a replacement program (full logic board swap-out). Sadly the program has ended.
  • What also occurred the solder joints holding the chip to the logic board also failed due to the excessive heat these chips create when running heavy graphics (i.e. gaming & video).
What happens is the tin within the solder crystalizes turning a conductor into a semi-conductor. While some people have reheated the logic board to the point the solder reflows the problem with this solution is the solder has already crystalized so it just happens again quite quickly (as you have discovered).
The only way to fix this correctly is to completely remove the solder on both the chip and the logic board pads and re-ball the chip with fresh solder. I would also cheat here if you still have some high temp lead based solder as the new stuff (lead free) just can't handle the heat.
At this point in time its getting hard finding good logic boards to swap out and the rev B chip is also hard to find new.
Re-balling is a tricky job unless you know what you are doing and have the correct tools I wouldn't try it. Many people kill their logic board in the process and besides you likely have the rev A chip so you still have a problem internally within the chip.
OK, We went over the chip side of the problem. Now we need to talk about some of the other causes of the chip getting hot. Putting aside the applications that are heavy on the GPU.
There are things you can do to help your system. For starters I would monitor the thermal sensors more aggressively using an app like: Temperature Gauge Pro. I would also clean and re-apply a good thermal past on the CPU, GPU & Hub controller chips using: Arctic Silver ArctiClean & Arctic Silver Thermal Paste. I would also make sure the fans and the heat sink fins where clean of any dust buildup and make sure the rest of the system was clean internally.
Arctic Silver ArctiClean 이미지
상품
$9.99
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
+++Dan is absolutely right. It is a design error on Nvidias part. The IC in question are of the Flip-Chip design with high lead bumps (solder balls) and this is the cause of the failure. Different stresses caused by uneven power demand of the IC are the biggest (as well as a few other issues on the design) issue for the failure. For a permanent fix, you would need a newly revised IC. A reflow or even a reball with the same revision IC will only be a very temporary fix.
댓글 달기
귀하의 답변을 추가하세요
manishrchandran 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 16
전체 시간: 1,827
