주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Chrome 운영 체제(OS)에서 실행되는 14인치 HP 브랜드 노트북 컴퓨터인 HP Chromebook에 대한 수리 안내서 및 문제해결 정보입니다.
Unable to charge chromebook
My son's HP chromebook's charging ability got worse and over a few months last year, to the point that it does not charge at all. The cables have been demonstrated to be working. Has anyone attempted to fix the issue - I'm guessing that the charging port "desoldered" from the board but I haven't had the chance to take it apart yet.
Thanks!
Keith.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 2개
I have the same issue, and getting ready to toss it too.
Not good, because the laptop isn't even a year old.
Warranty was 90 days
의
I work at a school doing chrombook repairs. We honestly haven’t found a reliable source for 14” batteries that are reliable. Most of them fail and have awful battery life. The 11” are the best we’ve found.
의
댓글 달기
답변 4개
선택된 해법
I also have this issue my Chrome book will not charge at all I am going to attempt to replace the dc jack if you have the model number q020nr I believe the dc jack is replaceable with out soldering.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
가장 유용한 답변
I have had this problem as well on multiple occasions, even after sending the Chromebook in for a replacement. It appears to be a serious defect for the device.
I've tried jiggling and wrapping the cord around the computer, with mixed results. At this point, I may simply throw the computer in the garbage and get a Samsung model.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I had the same thing happen to me. I opened up the Chromebook, and did some poking around. Everything looked fine. I put the device back together again, and it started charging again. I probably caused “Embedded Controller” to reset as in this article https://thedroidguy.com/2018/05/troubles...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I have had this problem most of the time the solution is to do a hard reset which is done by holding the power and refresh keys for 10 seconds
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
kmattox 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 13
전체 시간: 4,754
