주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
Battery will not charge
I replaced the broken screen/lcd on my wife's phone and it all works fine except the battery will not charge. the charging symbol comes on and the phone beeps when you plug in the charger connector. the battery was perfect prior to the screen repair. I cleaned as i reinstalled with IPA on all the electrical contact points.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Did you make sure to reconnect the battery connector to the logic board? The phone shows the charging symbol, but doesn't gain percentage? Is that what you mean by not charging?
댓글 달기
답변 2개
선택된 해법
Try reseating the battery cable, then cleaning and reseating the charging dock connector and cable as well. If that doesn't help,
Examine the battery connector and around it on the logic board.
Also examine the charging dock connector and around it.
Do you see anything damaged, broken, missing, part removed from the board? How about the battery cable itself, is it torn in any way? Are the battery connector solder points broken?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
You can at first try another battery, if that doesn't work check the battery connector (especially the middle 2 pins).
When it is at the charger, does it drop percentage or does it just not change?
You can also try charging it when powered off for 1 hour and then check again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
brendanoriordan 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 5
전체 시간: 155
