주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
질문 마감됨
iPhone 5s won't turn on after Camera replacement.
I followed the iFixit camera replacement guide and after I finished it the phone wouldn't turn on. So I changed the camera back to the original. And it still wouldn't turn on. I double checked the steps. And still no luck. Can someone please help me?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Maybe you forgot to turn the device off. Disconnect the battery and power up again.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for your help. I tried what you said with still no luck. I read through the article again and it said if you put the wrong screw in the wrong hole it can cause severe damage to the logic board causing boot disfunction. That's most likely what I've done. After that I made sure the right screws were in there place. And disconnected and reconnected the battery. With trouble still.
댓글 달기
Have you tried starting it up without the camera plugged in?
else if you have mixed up the screws on the shield which covers the lcd/digitiser/front camera, you could have damaged the traces
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 491
