주요 콘텐츠로 건너뛰기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
1697 질문 전체 보기
질문 마감됨
Broke the 5 wire conector from psu in the motherboard
Hi, while trying to take out the power supply, accidentally took the entire conector (5 black wires)that is in the motherboard(out of it). Now i'm afraid that i won't be able to solder it. Is a simple solder or i'm screwed?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
This all depends on whether you tore off the pads on the motherboard or not. You should be able to tell by cleaning them good. If they still have solder on them and they are not loose then they are probable fine. You can also look on the connector to see if any solder pads are stuck to the pins.
If they have not been torn off then it's just a matter of soldering the pins back on which is fairly simple. If they have been torn off then you need to solder a small wire from the connector pin to the copper trace on the motherboard that corresponds to that pin.
I hope this helps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 132
