주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Repair guides and support for LED, LCD, HD and other Vizio TVs.
white screen on tv
white is to bright to see picture? turn it off and back on picture came back on.Then does it again after a minute or so.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 7개:
wardharold, first what is your TV's model? then explain the "white to bright" a bit more. Does your TV turn white, as in only the backlight is on or can you still make other things out on the screen. The better you describe the symptoms, the greater the chance to get a good answer. Remember we can not see what you see, so we can only go by what you tell us.
sorry,yes you can see picture,but it`s like you turned brightness up 200%
vizio vw46l fhdtv10a is md #
The VW46LFHDTV10A has an issue with a variable resistor to come of the board. Of course, you want to check all the connections, pay particular attention to the T-con board connectors.
댓글 2개 더보기
댓글 달기
답변 1개
my vizio tv turns on, no logo, then shows black screen then slowly turns into a white screen. Please help
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
wardharold 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 8,882
