주요 콘텐츠로 건너뛰기
Apple 이외의 컴퓨터 키보드 수리 정보.
How to repair charging port?
When I last went to plug in my micro USB charger into my Zagg universal Bluetooth keyboard, the charging port was pushed further back into the keyboard. How do I take it apart to repair this device? There are no visible screws anywhere.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 4개
가장 유용한 답변
I just took mine apart. Use a heat gun to soften the adhesive, and slowly remove the rubber, then the case will seprate. The mirco USB connector is weak, and I have had several fail already. this part would otherwise be easy to replace, as it clips on, but Zagg will not sell the part. I may try to bypass the port, and charge directly to the battery...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Not sure if this will help but here it goes. The connection was very loose and cable would fall out. The port was not loose, just seated far back. I took a file and filed down the cable plastic on the connector so it angled properly in relation to the case and port. Problem solved.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Bought a new keyboard after mi puts roba
이 답변이 도움이 되었나요?
점수 0
댓글 달기
it broke off during normal use plus the wand has stopped working
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
were do i buy new keyboard and wand
댓글 달기
답변을 추가하세요
Lucas 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 68
전체 시간: 5,502
