주요 콘텐츠로 건너뛰기
The Skullcandy Air Raid is a wireless portable Bluetooth speaker released November 15th, 2013 which streams music from any Bluetooth-enabled device.
Why won't my device connect to the Bluetooth?
My Bluetooth device will not connect to my Air Raid. How do I connect?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 7
댓글 2개
Trying to pair my Soundmine to my Samsung phone but get an "incorrect passcode" message. HELP!
How I connect my skullcandy in my MI note 3 ? It's some issues while I am using . Sounds has automatically up and down ? What I should do for it ????
댓글 달기
답변 5개
가장 유용한 답변
the sound mind i turn it on and connect to it. phone showes up increrect pin or passward how do i fix this
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
I have this problem too and idk what to do.
conect your phone and headphones to the computer and turn on and off ur headphones couple times it will detect your phone .it happend to me and fixed it this way.i hope that help
댓글 달기
I have a samsung s6 and to fix I held to power button on the soundmine until it was flashing red and blue, then enabled quick connect on my phone.
Hope this helps.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Hit "forget this device" and search for bluetooth devices again.
댓글 달기
Mine won't connect to my blu phone it keep asking for a pin code
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Try 1234 or 0000 those are default for most electronic accessories these days.
댓글 달기
My air raid sont connect to the bluetooth
이 답변이 도움이 되었나요?
점수 0
댓글 달기
In order to connect the Bluetooth-enabled Air Raid to your phone, Press the center button on the Air Raid. After making certain that the other audio device Bluetooth is on, the LED light should flash a blue light once every 5 seconds as long as the Air Raid is connected.
이 답변이 도움이 되었나요?
점수 -1
댓글 2개:
If you want to write a guide it would be welcome. This is not the way to do it.
you can go to Skullcandy Air Raid Troubleshooting for more help troubleshooting
댓글 달기
답변을 추가하세요
Sasha Nevin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 15
전체 시간: 58,361
