Why wont my iPhone fit?
I am trying to get a new iphone to fit and it wont work at all
좋은 질문입니까?
좋은 질문입니까?
Make sure your iPhone has the same connector as the iHome iH9. If it has the same 30-pin connector, make sure the iPhone is fully seated in the docking station and the correct device "sleeve" is in use.
이 답변이 도움이 되었나요?
Your mention of the words "new iPhone" leads me to believe you're trying to plug a device with a Lightning connector into the iHome's older generation 30 pin dock connector.
Apple's proprietary 30 pin dock coonnector was discontinued late in 2012 in favor of the Lighting connector, which is smaller, faster and double-sided so you can plug it in in either orientation.
The sixth-generation 160 GB iPod Classic and the iPhone 4S were the last Apple devices to feature the 30 pin dock connector. So if your iPhone is a 5 or greater, you have a Lightning connector that won't plug into the iHome.
That being said, according to the iFixit device page on the iHome, there is an adapter available that will allow you to plug your Lightning port-equipped phone into the iHome. I personally don't have any experience with these sort of adapters, but I do recall my brother stating that he'd had no luck making them work himself. You mileage may vary, though, so if you want to use your iHome it would be worth a try.
이 답변이 도움이 되었나요?
Mustafa Kocaoğlu18:11 (1 saat önce)sehr gehrte damen herren ich brauche für mein radio ıbt4gc komplett display mit flatkabel wenn sie haben ich warte gern angebot mit bild mit freundlichen grüsse
이 답변이 도움이 되었나요?
Hallo Mustafa! Wenn du ein Display für ein Smartphone, Tablet oder einen Laptop suchst, schau dich am besten in unserem Store um (https://store.ifixit.de/). Displays für Radios haben wir leider nicht im Sortiment; für Radios haben wir aber viele Reparaturanleitungen (https://de.ifixit.com/Search?doctype=gui...). Ich hoffe, du findest etwas, was dir weiterhilft!
This iHome has a 30 pin connector. Your new phone may have a Lightning connector. Your iPhone needs an adapter if it has a Lightning connector. Or, if your device has a 30 pin, it may not fit the inserts.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 318
