주요 콘텐츠로 건너뛰기
Apple의 MacBook Pro 노트북 라인은 전문가 및 파워유저를 위한 제품입니다. MacBook Pro 라인은 MacBook Pro 13" Unibody, MacBook Pro 15", MacBook Pro 15" Unibody, MacBook Pro 17" 및 MacBook Pro 17"Unibody를 포함합니다.
20006 질문 전체 보기
MacBook Pro 2010 Mid 15" 1333Mhz 8G RAM Upgrade?
Hi all,
I had a 2nd MacBook Pro 2010 Mid 15" with i7, 4G Ram (It is a 1333Mhz, and using 1 Bank, so I still one bank RAM slot is empty right now).
I had search Google before, and look like this model work with 1066MHz only, but I am not too sure. Since new on this.
I want to buy other 4G Ram then install it to the empty slot.. But now, all 4G Ram is 1333Mhz, can't find the 1066MHz Ram anymore on 1st Market ...
Do anyone using this model who success install two 1333MHz 4G ram running on it?
I am using OS X 10.9.5 and OS X 10.10.2 with dual boot on it..
Thank you.
Best Regards,
Jimmy Chan
My web site
My blog
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개
ABCellars,
Thank you. I had using my old T420s's 1333MHz 4G install on my MacBook Pro 15" 2010 Mid.
It work with two 1333MHz 8GB now (Two different brand RAM together)
Thank you.
댓글 달기
답변 2개
선택된 답변
It has been known to work most of the time, sometimes not. However, putting faster memory sticks in won't buy you better performance. You are limited by the clock speed of the front side bus and memory controller. You are restricted by the design the engineers originally intended the limits to be.
Match the existing stick of RAM and you should be fine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It doesn’t work on 1333mhz and wouldnt make any real performance difference. Ive had a laptop that i was able to turn on with 1333mhz after fitting but then wouldn’t cold boot the next morning.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Jimmy Chan 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 648
