주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
7.9 inch display / Model A1432 / Available in black or white / Announced October 23rd, 2012 / 16, 32, or 64 GB capacity
it shuts down randomly
i reset it like 10 times. but after a while it shuts down randomly. without any reason. please help all this happen after i update to 8.3
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
선택된 해법
If the issue is just a failed update, you can try to restore you iPad:
First charge your iPad using a known good charger for ~30 minutes to make sure it is holding a charge.
Start iTunes on your computer.
Then turn your iPad off, connect it to your computer, press and hold home button, and while pressing home button, turn your iPad ON.
After a short while, iTunes will tell you it detected an iPad in restore mode.
You will be prompted to download and install of the latest iOS, accept and leave it undisturbed until it completes the operation.
However, you must know that if the issue is a hardware issue, due for example to a drop, liquid damage, or any other board damage inside the iPad, a restore will not fix it. Worse, it could get stuck during restore.
So can you tell for sure that there was not another incident with your iPad such as a previous repair, or drop, etc.?
이 답변이 도움이 되었나요?
점수 3
댓글 달기
8.3 has had a lot of these issues do you get red screen or a blue screen followed by a reboot
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
yeah u are right
댓글 달기
답변을 추가하세요
armando olivarez 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 7
지난 30일: 15
전체 시간: 525
