주요 콘텐츠로 건너뛰기
iPad 2세대, Wi-Fi, GSM 그리고 CDMA 모델이 있습니다. iPad 3 출시 전에 일부 모델을 새롭게 하였습니다. 수리는 어렵고 열과 비집기가 필요합니다.
730 질문 전체 보기
Motherboard issues won't restore
So I have an iPad 2 and an iPad mini which seem to have similar problems. Both are recognized by iTunes as being in recovery mode. The problem is that when iTunes tries to upload the latest firmware to the iPad iTunes just hangs on waiting for iPad. Both iPads boot up to the Apple logo and show an empty status bar underneath the logo and that's it.
I've put both logic boards under a microscope and there are no obvious signs of damage. I was hoping that someone on here may have solved a similar problem or at least had some trouble shooting directions. I've tried multiple PCs and doc cables but no luck.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 1개
So do I...exact same problem...otherwise my iPad 2 looks like the day I bought it...not a scratch anywhere...so I am inclined to think that a hardware failure is the root cause...instead I seem to suspect that when the latest version of IOS came out...might be related...not sure if my iPad 2 was configured to automatically upgrade it's firmware or not or if this was even an option...otherwise, I am stuck with a boat anchor now...thanks
댓글 달기
답변 2개
가장 유용한 답변
Hello Brian, you can try a different connector port from another ipad that works, but I'm not sure if that will be the problem, it's hard to know!
Good luck dude, keep us posted if you want
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Shouldn't even answered the question, if you cannot solve the problem keep the question against you chest and wait until someone come up with a solution.
댓글 달기
So do I Brian...exact same problem...otherwise my iPad 2 looks like the day I bought it...not a scratch on it anywhere...so I am rather inclined to think that a hardware failure is NOT the root cause...instead I seem to suspect that when the latest version of IOS came out...this might be related...also not sure if my iPad 2 was configured to automatically upgrade it's firmware upon a new release and/or whether this was even an option...otherwise, I am stuck with a boat anchor now...the iPad store techs don't have any idea either...thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brian 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 4
전체 시간: 1,038
