주요 콘텐츠로 건너뛰기
Repair guides for the Motorola Moto G. A series of Android Smartphones manufactured by Motorola Mobility since 2013.
972 질문 전체 보기
Only backlight after screen replacement?
I work in a cellphone repair store. I have been repairing Moto G screen with no issues as they are really easy. But I was changing one of the customer's screen today and the phone will turn on and makes boot up sound and the notification led blinks too but, I can't see anything except there is just LCD back light. I have compared the motherboard with a picture online in case I damaged tiny I.C components but everything looks fine.
Any help would be really appreciated,
Thanks.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
isn't there a way to hard reset? had the same problem with a oneplus one
댓글 달기
답변 8개
Hi, I have the exact same problem. Did you figure out what it was?
Thanks.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi! I replaced my screen as well a while ago and had the same problem. Turned out i forgot to flip back the little switch located at the part where the screen connection plugs into the rest of the phone. Hope that helps!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Thanks HelpingHand! I tried that and it didn't work. I really don't know what else to do!
댓글 달기
change lcd it will work for me
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The flex connector probably got folded during installation causing it to crack slightly leading to break in circuit.
I think you need to replace it again if nothing else works.
Did you come up with a solution ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i have this problem can u solve them?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Try to hold the power button for 120 seconds while it is connected to a charger. (Yes, two minutes.) I am not sure if it wipes all your files, I remember it doesn't.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
tnx i try this and also 120sec power+down key and nothing just black screen
while rom is up every thing is work i get screenshot and connect phone to pc and see screenshot file and all is ok just screen in black
댓글 달기
I have the same problem... I changed the screen it was working fine but i forgot part of earphone; hence i disassembled and assembled again... now screen doesnt work!
help please....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Have the same problem. Not flex cable as I have tried two different screens and have the same problem with both. Phone is powered up and running but at first had the blinking white light which I understand to be the dead battery light. It worked fine the first teardown then once a new screen went in neither of them worked. What else ?
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
osheanjuneja 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 7
30일 전: 16
전체 시간: 3,425
