주요 콘텐츠로 건너뛰기
2010년 4월 출시 / 2.4, 2.53 GHz Core i5 또는 2.66, 2.8 GHz Core i7 프로세서
590 질문 전체 보기
Bluetooth no longer functioning after installing dual hard drives
okay so after sucessfully removing the optical drive and installing an SSD, with the help of your guide, (Thank you!) everything seams to be running smoothly except that my bluetooth is no longer functioning. I have gone back inside to disconnect and reconnect twice now, and I do not see any physical damage, however it is still not cooperating.
Has anyone else had this problem? Any advice would be very much appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
가장 유용한 답변
I would start by replacing the AirPort/Bluetooth cable 922-9296 as you may have damaged it in the process of taking it off.
Let us know how it goes.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
The airport is still working completely fine though, if the cable was damaged wouldn't both the bluetooth and wifi be out of commission?
Not necessarily. Its the only thing you pulled off to get to the optical drive bay. Did you slip and nick something with your screwdriver on the AirPort card?
댓글 달기
There is a piece of black tape that goes over the pins of the wifi/bluetooth/webcam connector. Then, sometimes, there is this little mesh blob thingie that goes on top of the connector/cable.
If the black tape is no longer there, but you put the mesh blob thingie back, it will short pins of the connector. So toss that little mesh thingie in the trash and you will probably have a working setup back.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
"little mesh thingie" Louis are you talking about the EMI shielding pad which is conductive? Yes! I agree, you do need to make sure it's not shorting out the board.
댓글 달기
Hi there,
I have the same problem after installing a SSD. The old HDD replaced my optical drive. I replaced the Airport / Bluetooth Card (to the ...CAX one - to use hopefully handoff) without success. Next step was to replace the flex cable... Still the same Problem. WiFi works without Problems, only Bluetooth is not available.
PRAM, SMC reset didn't help either.
Has anybody an idea?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Does Bluetooth services work at all? If you are having problems setting up Handoff you should review this: Continuity Activation Tool
Are you sure you have the antennas correctly connected? It you are switching the board out the connections are laid out differently between them.
댓글 달기
Thanks for your reply!
@Dan, Bluetooth is not working at all. I checked the wiring and connected them as described in Mid-2010 MBP upgrade success (MacBookPro6,2)
@Louis Rossmann
I'm not quite sure what you mean with "little mesh blob thingie". Can you see it on the picture?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Did you try a different board? Maybe this one is bad.
댓글 달기
귀하의 답변을 추가하세요
acacella7 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 160
