Dropped Phone, what component went bad?
Phone keeps restarting by itself. Sometimes when i am using it other times without me touching it. What can the problem be?
좋은 질문 입니까?
좋은 질문 입니까?
Hello!
That sounds bad, hopefully it can be a ribbon that has been moved a bit from its place, but seems like the board has been damaged.
The procedure is to open your iphone carefully and check all the ribbons attached to logic board. Check if they have moved, or even better, disconnect all and reconnect them again.
Inspect if some component has blown or logicboard part has crushed.
You can follow this guide to reach the logic board : iPhone 5 Logic Board Replacement
Best of luck!
해당 답변은 도움이 되었습니까?
I forgot to mention! Be carefull when removing the connectors, near them there are several microcomponents that you should not damage.
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 89
