주요 콘텐츠로 건너뛰기
This tablet was released by Asus on July 2013. The model is also called ME173X. The tablet features a 7 in. display microSD card slot, a MicroUSB slot, and a headphone jack.
20 질문 전체 보기
How to change my tablet charching port.
because, when i try to charcge it it won't work
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 9
댓글 달기
답변 2개
가장 유용한 답변
There is a possibility that it may not be the charging port, but a bad battery. If it is the battery, you have to replace it with a new one. Please use our guide on how to replace the battery:
Asus MeMO Pad HD 7 Battery Replacement
If it is the charging port that is defective, you must follow our guide on how to detach the motherboard:
Asus MeMO Pad HD 7 Motherboard Replacement
Once you remove the motherboard, you are going to have to remove the solder at the four soldering points that keeps the charging port in contact with the motherboard. With your new charging port, you must solder it using the four soldering points on the motherboard.
If you do not want to solder the charging port off and solder a new one in its place, we recommend buying a whole new motherboard. Luckily, we sell the motherboard on iFixit:
ASUS MeMO Pad HD 7 Motherboard
Main circuit board assembly 이미지
제품
$29.99
Asus MeMO Pad HD 7 Battery 이미지
안내서
난이도:
쉬움
15 minutes
Asus MeMO Pad HD 7 Motherboard 이미지
안내서
난이도:
조정
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Related to this answer/scenario, would replacing the whole motherboard be equivalent to resetting the tablet? In other words, is the device memory included on the board such that replacing it would be a clean slate? Thanks!
Yes it is, it's basically like getting a brand new tablet so you will need to reinstall all of your apps and you will lose anything that you haven't backed up. Anything saved to your memory card will be fine as you can just swap that across.
댓글 달기
The the charging port need replacement
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ivan Rafael Ramirez Romero 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 2
전체 시간: 10,532
