주요 콘텐츠로 건너뛰기
The 2014 version of the Galaxy Note 10.1", running a Exynos 5 processor and 3 Gb of ram. Released October 2013.
119 질문 전체 보기
touch screen works only by edges not in the center
hi!
i have the Samsung Galaxy Note 10.1 2014, but recently the display stop working, i check a blog and read how to fix it, now the display is working but the touch screen is working only by the edges the center dont respond.
P.S.: the is working fine and im using the tablet with these.
what can i do?
HELP!!!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 1개
가장 유용한 답변
Hello Jose,
-Disconnect and reconnect the digitalizer ribbon from logic board.
-Clean the digitalizer connector with a isopropyl alcohol and a soft brush
-If there is a calibration option, do it
If that doesn't work, probably you'll have to buy a new digitalizer!
Hope that helps, good luck!!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Jose Manuel Romero Minet 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 228
