주요 콘텐츠로 건너뛰기
Repair and disassembly guides for Brother printers.
My brother printer won''t connect with my wireless router
my brother printer does not connect with my wifi router . all other devices are connected with router . i don't know my wireless pronter is broken or what how do i check that .please help me
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 54
댓글 28개
What's the model number of the printer?
thanks everyone ..it was very helpful
If you've recently switched from 2.4GHz to 5GHz wifi - this is the problem! Brother printers cannot connect to 5GHz wifi, but if you ask your internet provider, they can split the combined network into two separate networks, a 2.4GHz one and a 5GHz one - then connect your printer to the 2.4GHz!! I spent far too long trying to figure this out, so I hope this saves someone the hassle.
Turn on your Brother Printer
To reset the wireless connection press the Menu button
Press OK.
Select Network Reset.
Press 1 to Select Yes.
Press 1 again to confirm the reboot
The printer will now reboot and the network reset has been successfully done.
Follow the next step in order to connect your Brother Printer to Wi-Fi.
Connect Brother Printer to Wi-Fi
Once you restart the Brother printer after the network reset you’ll see a message Wi-Fi setup will start. Refer to Quick Setup Guide
Then Press OK
Press Ok three times to get inside Setup Wizard
A message will appear on your screen Enable Wlan? Press Ok to accept. Press Ok Again
Wait for a moment while it searches a wireless network
A list of SSID will appear on the screen choose the Wi-Fi network you want to connect with and you need WEP Key/Wi-Fi Password of your router to connect Brother Printer to Wi-Fi
Enter the Wi-Fi password using the Brother Printer Keypad
Next Press Ok and then Press 1 to apply the settings
Get as far as entering wireless network but doesn’t ask for password?? And so just reverts to home screen??
댓글 23개 더보기
댓글 달기
답변 22개
선택된 해법
Hello, if you are having trouble connecting brother printer to wifi then you have multipal options and methods to configure the brother printer to wifi.
  1. Wifi Methods using Printer driver
  2. WPS Method (Push and Pin method )
  3. From Printer Panel
to know the methods in detail please Go to https://fixingblog.com/setup-brother-pri... to find the steps.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
I had updated my firmware to the latest one. After that whenever I try punching in the wifi passkey, it shows connection fail. Whichever method I use it shows connection fail. My printer model is HL-B2080DW. Even Air Print is not working. But WiFi direct does work along with USB too. I am at my wits end...
This was my error: unable to connect to ‘brother MFC-L2717DW._ipp._tcp.local.’ due to an error
The solution was ridiculously simple.
I created 3 separate networks home(2.4,5), 2.4, 5. 5 only accessible at close range. 2.4/home entire house.
I switched from 2.4 to home. Was able to cleanly finish the setup.
Could you link to an article by someone who knows English? That article is unreadable.
댓글 달기
가장 유용한 답변
If your Brother printer won’t connect to your wireless router 855.324.7676, check that it’s within range of the Wi-Fi signal. Ensure the correct Wi-Fi network and password are entered. Restart both the printer and router, and try reconnecting. Also, confirm that your router’s settings allow the printer to connect.
이 답변이 도움이 되었나요?
점수 35
댓글 달기
In most of the cases, people face brother printer won’t connect to wifi due to the incorrect username and password for the wifi. so you should check the password an encryption type first.
If you are still going through similar problem, you need to reset the network settings on your printer and then try to connect your printer again.
이 답변이 도움이 되었나요?
점수 13
댓글 달기
First you have to reinstall the Printer drivers and connect with WiFi and check Printer IP address on router page IF your IP Address is there so Come to your computer and Go to Control panel - printer and devices - and click on left top corner and click on Add devices and you will get your printer name over there and connect with that devices.
이 답변이 도움이 되었나요?
점수 12
댓글 4개:
Connection fails.
My printer won’t connect to WiFi after being powered off and turned on again. WiFi button just keeps blinking. I’m about to go office space on this $@$* and take a bat to it.
Mine suddenly won’t connect either. Telling me the WiFi password is not correct, but it is.
Turns out other than restarting the router, I restarted the printer and now it connects. Annoying!
댓글 달기
Printers are a headache if you don't know where to start. So here are some steps you can follow, depending on your printer:
1. First of all check if the printer has a small interactive screen, where you can navigate through a menu of some sort. If it does, look for an option that says 'setup wizard', then you have to follow the steps the printer gives you. You might have to choose setup wireless network after selecting setup wizard. Afterwards, you might get a screen with a list of wireless networks available, choose your home network (the one you use with your other devices in the house), then it will ask for your password, type it in (password is case sensitive, so be sure to type uppercase letter if needed). After that, you need to wait for a confirmation message saying you are connected to the network. The printer should work.
2. Check if you printer has a wifi button (it is a button that connects to a network automatically.) The button might have a small antenna image, or a wifi image. To use this button you will have to press the setup wireless button on you router/modem first. It should blink, if it does, then go to your printer, press the wifi button, and wait for it to link. If this works, you should get a confirmation message or the wifi button's light will go solid.
3. If your printer doesn't have either a screen or a setup wireless network button (wifi button or WPS), then you should have a usb cable attached to the printer and your computer for it to work. After you connect it, you should look for your printer's setup wizard in you computer in order to setup the wifi settings of the printer.
이 답변이 도움이 되었나요?
점수 6
댓글 3개:
I did the first example and it said it was connected but It isn't printing still
I did the first example also however my printer continues to say connection failed
I also did this, and the printer still won't respond to WiFi, though it prints when wired to my desktop just fine
댓글 달기
I just tried for the last couple of hours to connect my HL-5370DW (it's years old, with no WPS, but I love this printer!) wirelessly with our new cable provider router, as opposed to the router of the cable provider we had just left. I FINALLY succeeded!
TWO THINGS were vexing me when using the Setup wizard with a network cable.
FIRST, the printer wasn't being recognized when searching for available wireless devices. To solve this you need to RESET THE PRINTER'S NETWORK SETTINGS to the factory default. After the reset the Setup Wizard will recognize the printer. From the 55-page Quick Start Guide, p43:
1. Turn off the printer.
2. Hold down the GO button as you turn on the power switch. Keeping the GO button pressed, all the LED lights will light, and then the Status LED will turn off. Release the GO button. All the LEDs should now go off.
3. Press GO six times. All LEDs should light up, and then the printer will restart.
4. The printer will now be recognized.
SECOND, I was continually getting the "FAILED TO ASSOCIATE" ERROR MESSAGE after going through the connection steps (Note: As a guide I was following screen-captured instructions from the last time I had to do this with the previous cable provider).
In my case, the encryption mode for the WPA/WPA2 authentication method changed after getting the new router. Previously, the encryption method was TKIP. The new router, however, was AES. When I changed the encryption from TPIK to AES, the printer connected immediately and all was right with the universe!
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Oh my God. I was absolutely losing my mind trying to get my Brother MFC-L5900DW printer to work. This comment changed my life. Thanks a quintillion.
You are amazing!! I have been beating my head against the wall about this off and on for YEARS now. Thank you, thank you, thank you!!
댓글 달기
I solved my problem with connecting WIFI. When prompted to input Password key make sure after all digits are entered mover curser off (right) of last digit. Then press OK.
이 답변이 도움이 되었나요?
점수 2
댓글 3개:
Thank you mxfrank2001 that SOLVED my problem.
nothing else worked I cant believe the system was that stupid! THANK YOU SO MUCH!
i tried this > I moved my cursor to the right of the network key I entered and I keep hitting Ok and nothing happens. I had selected Key1: and inputted my password under that menu. I have no idea what to do, so stuck : /
댓글 달기
Dial 1-888-966-6097 to Resolve Brother Printer not Connecting to Wifi issue. Are you experiencing difficulties with establishing a connection between your Brother printer and networking device? If so, you are in the right place. After exploring this section, you will be aware of various potential reasons for this issue. Once you understand these reasons, you can troubleshoot as well as resolve such connectivity issues more effectively.
Let’s have a glance at the factor responsible for the issue namely - ”Brother printer not connecting to Wi-Fi” -
  • Network Issues
  • Weak Wi-Fi Signal
  • The printer is too far from the Wi-Fi router
  • The inability of the printer to receive a strong enough signal to connect
  • Physical obstructions like walls and furniture
Troubleshooting Tips To Resolve Brother Printer Won’t Connect To Wi-Fi
  • Ensure your printer is within the range of your Wi-Fi router.
  • If the signal is weak, try to move the printer closer to the router
  • Keep the printer away from electronic devices such as microwaves, cordless phones, and other Wi-Fi devices
  • Double-check that you have entered the correct SSID and password
  • Confirm that the network name and password are case-sensitive
  • Ensure your router is broadcasting a 2.4 GHz signal
  • Turn off your Brother printer
  • Unplug your router
  • Reboot the computer to clear any potential conflicts
  • It will be worth visiting the Brother support website to check if there are any firmware updates for your printer model
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Dial 1-888-966-6097 If your Brother printer won't connect to Wi-Fi, here are some troubleshooting steps you can follow to resolve the issue:
1. Check Wi-Fi Network
  • Ensure the Network is Active: Verify that your Wi-Fi network is working by connecting another device, like a smartphone or laptop, to the network.
  • Correct Network: Make sure the printer is trying to connect to the correct Wi-Fi network, especially if you have multiple networks.
2. Restart Devices
  • Restart the Printer: Turn off your printer, wait for about 30 seconds, and then turn it back on.
  • Restart the Router: Power off your router for about 30 seconds, then power it back on. Wait for the router to fully reboot before trying to connect the printer again.
  • Restart the Computer: If the printer is managed by a computer, restart it as well.
3. Check Wi-Fi Signal Strength
  • Move the Printer Closer to the Router: Weak signals can prevent the printer from connecting. Ensure the printer is within a reasonable range of your Wi-Fi router.
  • Remove Obstructions: Ensure there are no large objects or walls directly between the printer and the router that could block the signal.
4. Reconnect the Printer to Wi-Fi
  • Use the Printer's Control Panel: Navigate to the Wi-Fi settings on the printer’s control panel.
  • Select the Network: Choose your Wi-Fi network from the list and enter the correct password.
  • WPS Connection (If Supported): If your router supports WPS (Wi-Fi Protected Setup), you can press the WPS button on your router and then the WPS button on the printer to connect automatically.
5. Verify the Wi-Fi Password
  • Double-Check the Password: Ensure that you are entering the correct Wi-Fi password. Passwords are case-sensitive, so pay attention to uppercase and lowercase letters.
  • Re-enter the Password: If you’re unsure, re-enter the password on the printer to ensure accuracy.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
reset the printer and un-install the software and install it once again .setup the wireless printer once again and make sure your router password .
이 답변이 도움이 되었나요?
점수 1
댓글 달기
PROBLEM SOLVED... I have multiple ip addresses that I can connect to, like most people now. The trick is to make sure you are connected to the exact same IP address as your printer is on. Once I made sure my laptop was always connected this way, I have had zero issues with this.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I found out that the router needs to be set to include the WLAN standard 802.11b in order to connect the printer (HL-2135w) via WPS.
My router was set to 802.11g+n which is fine for printing via WLAN once the printer has received the credentials of the WiFi network. The router tells me that the printer is using 802.11g within the network.
But apparently the printers WPS mode is only working via 802.11b. When I set my router to 802.11b+g+n the first connection attempt was successfull.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Before connecting you brother printer to wifi, you must know this information about your network:
. Network name (SSID)
. Security Key of the network.
You will get these details on the backside of your router.
1. Use the control panel on your Brother Printer to set up wirelessly.
2. First of all, connect the power cord into your printer and turn on the printer.
3. Then press Menu.
4. Now press up or down arrow key to choose network setting or wireless setup.
5. To choose the network press up or down arrow key and then press ok.
6. Choose the WLAN by pressing up or down arrow key and after that press ok.
7. Next press the up or down arrow key to choose the setup wizard and press ok.
8. Enable the wireless network when the LAN enables. This will start the wireless setup Wizard.
9. Now the brother printer will search for your network and display a list of available network. Choose the SSID you want and press ok .
10. After that type the SSID Key.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Non of the above worked for me, I manually entered in the IP address, dns server, dns gateway and subnet mask in to the printer directly which worked like a dream. I found that the printer had given itself the wrong IP address and associated details which is why it didn't work.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
How to find out IP address,DNS server,DSNS Gateway and subnet mask etc.,
댓글 달기
Just figured out how using this video. Messed around for some time until I followed this video and now I can print wireless https://www.youtube.com/watch?v=mg1R0QYY...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
HLL2390DW printer will not connect to the internet!
This is not a new problem. Three years ago, we had the same printer, as soon as we changed the toner cartridge, several weeks later it stopped working,. We could still copy on the printer, so it was working as a copy machine. We had to buy a new printer. Again, we bought Brother. Same thing again, after two years we bought a new toner, a couple of weeks later stopped working. After hours of programing…..no luck. When it was new, it set up so easy….is this a scam….the printer is obsolete after two years!!
We will not be buying Brother again!
Husband was a Brother dealer for many years! Disgusted!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Never again for me either. Have to reset router every time. So friggin annoying. You lost my business for sure.POS
댓글 달기
Printer: Brother DCP-L2550DW
Router: NETGEAR R7000P
Error: Printer can’t find the NETGEAR SSID using Setup Wizard, but could see neighbors SSIDs.
Solution: Set Brother Printer Domain Name Server number same as NETGEAR Internet Port DNS number. Run Setup Wizard, SSID is found. Enter network password. Connected.
1.  Press ▲ or ▼ to select Network, press OK.
 2.  Press ▲ or ▼ to select WLAN (for wireless connection), press OK.
 3.  Press ▲ or ▼ to select TCP/IP, press OK.
4. Press ▲ or ▼ to select DNS Server, press OK.
5. Set DNS number same as NETGEAR Internet Port DNS, press OK
6.  Press ▲ or ▼ to select Network, press OK.
7.  Press ▲ or ▼ to select WLAN (for wireless connection), press OK.
8. Press ▲ or ▼ to select Setup Wizard
9. SSID should now be found, enter network password.
NETGEAR DNS varies depending on configuration and ISP. Once logged into router see, Advanced > Setup > Internet Setup to view DNS
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Wireless printers work using a network connection, the steps to connect the printer to your Wi-Fi depends on the printer’s make. So, before you begin, read the instruction manual to continue.
Configure Internet on the Printer-
  1. Power on the Wi-Fi router and your laptop
  2. Power on your printer
  3. Go to your Brother’s printer Wi-Fi setup to connect it to your Wi-Fi
  4. Select the SSID of your Wi-Fi network
  5. Change your Brother’s printer default password from the printer and enter the Wi-Fi security password of your Wi-Fi.
  6. The light indication of the printer will come on confirming the printer is connected.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Check to see if you are trying to connect it to 5G. I decided to try the 2.4G and that was the fix I needed.(my router supports both)
My MFC-2701DW will not connect to 5G. I wish that information was given to me clearly from Brother. So, how I proceeded.
I did reset the network on the printer (option in the network section of the the printer)
Rebooted the printer.
Went into setup Network - WLAN(Wifi)
Found the SSID and entered it then it asks for the key, typed it it..it said connected right away.
If you need or want more info, ask here. I will try to pay attention to this thread.
Hope this helps someone.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have my printer hooked up to wifi and it even prints bluetooth, but my computer says cant find network 4. So I cant find my printer on computer.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
My brother HLL3210CW printer suddenly fell off the network after several years. While trying to re-connect it would randomly see or not see the correct network but would not connect to it and return a message that it failed to connect. I am using a Netgear Nighthawk MK63 Mesh router system. The Brother printer requires a 2.4 Megahertz network which was available through the router but what I found was that with the router 2.4 Mhz in the AUTO setting for channel selection the printer would not connect. When I set the Channel selection to static setting to Channel 11 the printer connects immediately. Apparently the printer is very picky about what 2.4 Channel it wants. I did not try other channels to see if it would connect but Channel 11 works fine. Hope this helps some of you out there.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If your Brother printer won’t connect to Wi-Fi, reset network settings, restart the printer and router, and reconnect using the correct 2.4 GHz Wi-Fi and password. This usually solves most connection issues.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Emma 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 18
지난 7일: 153
지난 30일: 719
전체 시간: 468,174
