Screen Wont Turn on help please
When i turn on my laptop the light of the keypad turns on but my screen is all black? Need help please.
좋은 질문입니까?
좋은 질문입니까?
Dear All,
* Press Fn+F5 or Fn+F6 simultaneously while notebook is turn on
* if display switching not works just connect your laptop to external display and re-start (press and hold the power key until power LED goes off. after couple of seconds press power key again) and check any visuals on external display
* if you can see any visuals on External display, you should check the internal display and Flex cable and connector as well
* onc of above step not works for you, its time for advanced level repair to check the GPU output and and CPU clocks and Bus (Board level repair)
이 답변이 도움이 되었나요?
Thanx ifixit...Your information is very productive.. With your help i just fixed the problem with my acer v5..thanx again
Hi friend,
Kindly reset ur bios..otherwise properly fix RAM.
METHOD 1:
Step1: turnoff ur laptop
Step2:remove ur battery
Step3:hold on power button 30sec
Step4:after directly connect the charger trun on ur laptop its working .after connect battery.
METHOD 2:
First u identify ur RAM part of the ur laptop.
Just remove ur ram and clean tha pins smoothly.
After re insert the RAM check it ..working or not.
If u any doubt text me my number:+919524629460 whatsapp
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 3
지난 30일: 21
전체 시간: 12,699
댓글 5개
I have the same problem now. I know it's alive but no screen. I have my QuickBooks running and hate to force it turn off.
Alex Chang 의
My screen won't turn on , but lights on the keypads work?
Ana 의
The light on the on/off button turns on for a bit but the screen and the rest of the camera don't react at all when I try to turn it on? Surely if the batteries were dead the light on the button wouldn't turn on?
Ruby Marseilles 의
Is Completely Black , Looks Like Internal Screen Damage
Najeer Watson 의
Thanx ifixit your information is very productive. ..I just fixed the problem with my acer v5..thanx again
Mycurl Qwesi 의
