주요 콘텐츠로 건너뛰기
Apple iPhone 5c는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 8, 16, 32GB / 흰색, 분홍색, 노란색, 파란색 및 녹색으로 제공하였습니다.
1233 질문 전체 보기
iPhone 5c keeps switching from home screen to multitask switcher
iPhone 5c keeps rapidly switching from home screen to multitask switcher without pressing the home button. Almost as if the home button is stuck. When pressing the power button to lock phone or power down it takes a screenshot everytime the power button is pressed. Any ideas on what the problem could be or how to fix it?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
How/why/when did this started? What is the history of this phone and this issue? Such as: was it dropped, water damaged, repaired, purchased like this?
It's my wife's phone, bought it brand new a little over a year ago was recently lost and then found not sure what happened to during the time it was lost. Took to sprint to get repaired, said it had water damage. Not sure if the problem is related to that. As not been submerged in water to my knowledge.
댓글 달기
답변 3개
선택된 답변
Follow the iPhone 5C home button flex cable replacement guide until step 8, and test the phone. If the issue stops, it means your home button flex cable is damaged or stuck somehow. May be due to water damage. Then follow the remainder of the steps to replace the home button flex cable.
If your issue remains, it means the damage if further down the line, probably at the level of the logic board. At this point you need to continue till step 13 to completely remove the screen, then examine the visible parts of the phone. You need to look for traces of liquid, corrosion, and water indicators turned from white to red. Let us know if you something of the sort.
Even if your home button flex cable is fixed, have that look. If you see traces of liquid, look for other threads about water damage repair, and follow the repair guides on this website to remove and clean the logic board and other important components. If you are not sure on how to do it, post a separate question.
해당 답변은 도움이 되었습니까?
점수 3
댓글 달기
The Home button may be stuck, have you tried unscrewing the home button and putting it back on the phone and see if that help?
Thanks
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have not tried that. Did not know the home button could be unscrewed. Can that be done without disassembling the phone?
댓글 달기
No brad it would need opened up unless you have powers like magneto
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Brad 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 330
