Slow charging time. Charging with 2.3 watts
Hi.
I have cleaned everything after someone spilled coca-cola on my macbook air 13" mid 2013.
After cleaning all components works, even did a full reinstall of yosemite.
But the charging time is extremely long. From 2% to 100% it took over 20 hours. According to batteryhealth it is charging with 2.3 watts.
Yes I have tried other chargers with the same result.
I changed the I/O board cable and suddently it charged with full power. But the next day when inserting the charger it is charging slow again with 2.3 watts.
So... are there any fuses I can change?
Or is it the battery that needs to be changed? Battery age 1.7 years, cycles 93, original max 7150mAh, health 95%.
But the health got to 99% when the charger was charging full. Now it is back to 95% when charging with 2.3 watts.
Taking it to a repair shop wont do any good...because one of the LSI indicators on the logic board is red. Yes I have reset SMC.
Update
I have bought a new battery and a new I/O board. But it is still charging with 2.3 watts.
Anyone know if it is a charge circuit on the logic board?
The new battery showing 106% health, Current max: 7608 mAh, original max 7150 mAh.
Update
Update (06/19/2016)
Now it is only charging with 0.8 watts :/
좋은 질문 입니까?
댓글 8개
Interesting.. I disconnected the battery before going to bed, then it had about 70%.
This morning I connected the battery and inserted the charger. I noticed that the charger was giving 44W with a monitor, the app "battery health" also showed full charging speed. After a few minutes it decreased to 2.4 watts again. :/
Mike 의
Hello, did you find any solution for your problem?
I have the same case with water :(
Igor Ivanovski 의
@igor Ivanovski - How about creating your own question with all of your details as this one is over a year old.
Dan 의
Igor: Still havent solved the problem. Only charging 2.3W.
Mike 의
Using the app Battery Health. Charging with 2.5W
Tried to reset SMC and changed battery.
Mike 의
댓글 3개 더보기
