주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Earpiece with no audio... Board problem
Hi there
I had just got my iPhone 5 16gb as a gift from USA
BUT unfortunately it got no service warranty
Few days after I had an error that earpiece stop working
I asked for help from some local service center specialized in Apple products
He told me that isn't earpiece or it's cable problem
It is audio ic problem which he considered it unrepairable
Did he says right ??
Is iPhone board could sold alone as spare part ?
Would I lose my data if I did change the board ??
Thanks a lot
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
Hello,
First off, does the front camera and/or proximity sensor work? those are also on the same cable at the ear piece. To test the proximity sensor would be to make a call and put your hand over the spot right above the ear piece. If the screen goes black then it works if it doesnt then there is something wrong with that cable. Another thing ive seen if is the phone thinks there are head phones plugged in it wont use the ear piece. That can be checked buy turning the volume up and down. When the pop up for the volume level comes itll say if head phones are plugged in or not. If it does then you would try cleaning the headphone jack, or you might have to replace that cable instead. The ear piece or headphone jack cable are very easy to do.
Here is the guide to replace the earpiece...
iPhone 5 Earpiece Speaker Replacement
Here is the guide to replace the headphone jack
iPhone 5 Lightning Connector and Headphone Jack Replacement
To answer you other questions, yes you could replace the board, but that is close to the same cost as another phone. You would lose all your data as well unless you did icloud for a backup and restore. I would suggest checking everything else out first before considering replacing the board.
iPhone 5 Earpiece Speaker 이미지
안내서
난이도:
운영
20 - 40 minutes
iPhone 5 Lightning Connector and Headphone Jack 이미지
안내서
난이도:
운영
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Thank you for your reply
Proximity sensor check OK
front camera check OK
headphone jack check OK
The service center I went to told me that he tried to replace both the earpiece and the flat cable but the error remains so he figured out it is on board problem
Would you recommend to try again myself using the above guides ??
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I do not think it would hurt to atleast try replacing them to make sure. the parts are rather inexpensive. its worth a shot, if the pro still shows that the ear piece doesnt work then something on the board would have to be damaged.
댓글 달기
귀하의 답변을 추가하세요
Hussam 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 192
