Flash will not pop up
The flash no longer pops up, when it should.
좋은 질문 입니까?
Adjust the hotshoe. Loosen it off and check the contact in the middle, as is sometimes stays depressed/gets caught when you remove the external flash. The camera thinks it has a flash attached and prevents the pop-up flash from coming up.
해당 답변은 도움이 되었습니까?
The 5d doesn't have a built in flash. You need to fit an external flash!
해당 답변은 도움이 되었습니까?
Hi Sally,
The Canon 5D is a full frame DSLR camera and has no built-in flash. So, I am assuming you are talking about an external flash (like a Canon Speedlite) which you attach to the hot shoe of the camera.
Tell us more about the flash (brand, type, etc.) and what settings you used when the issue occurred.
해당 답변은 도움이 되었습니까?
Eos 5 film had a pop up, but not the 5D
My Eos 500d has a pop up... Are you confusing the 5d
with the 500d??
해당 답변은 도움이 되었습니까?
with the 500d??
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 777
