주요 콘텐츠로 건너뛰기
The Blu Dash 5.0 Dual SIM D410 was released September 3 2013. Repairing this device is relatively complex and requires tools that have to be purchased.
70 질문 전체 보기
phone is coming on and staying on "BLU" ,how to fix it?
my phone is coming on and the screen is staying on the word "BLU" and not coming on fully
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 34
댓글 1개
How to solve this problem
댓글 달기
답변 10개
가장 유용한 답변
i'm having the same problem.. but when factory reset and restart it.. the problem do not change :-(
해당 답변은 도움이 되었습니까?
점수 4
댓글 3개:
i tried that method but it still didnt work..what other options do i have or what do you recommend?
Did u wipe the catch partition in the recovery? If not then try that. And if still that didnt help out. Then u may need to flash the phone. Look in here for answers on how to http://forum.xda-developers.com/android/...
i did it and phone not working
댓글 달기
you have to boot into recovery and wipe data or factory reset..
remove the battery and wait for some seconds then insert the battery again
hold volume down and power button together until u see a recovery menu, then choose wipe data/factory reset us volume down/up to navigate .. then restart when done..
WARNING!personal data Like SMS/MMS/Contacts/Apps/call history .... will be gone for good if you need those then consider taking the phone a pro for backup..
Media such us pictures/videos/musics will not be affected
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
I tried that but the same thing is still happening!!!!!!
i tried that but the same thing is happening
Did your phone ever started working properly. Again. Guys??
its the same thing happening ugggggggggh
can you help me how to update the software
댓글 달기
Have your tried booting in safe mode? A safe mode can help you to diagnise and uninstall the culprit app causing your mobile to stuck on boot screen. Safe mode can also help you to detect if there is any hardware or software issue on the mobile.
  • Power off your mobile
  • Hold the Volume Up+Power key together
  • Release the power buttom once you see the logo on the screen.(keep the volume key holding)
This will boot your Mobile in safe mode. Unistall any recent install app which you think migh cause the error.
Follow the detailed guide here: Android Safe Mode, What is Safe Mode? How to Use it to diagnose the Android problem.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks for the answer @somnio360. The guide was helpful and worked for me
댓글 달기
I had the Blu 4.0 star, and the brand itself is pretty bad :/ its a cheap brand, and I had that problem, and exchanged it, and the problem came up again :/ factory reset worked for a while, but it is a problem that will happened again and again. I would suggest a new phone.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
yesnmk,l.;/""""""""nxdc nm b .n
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
use volume down/up to navigate and power button to select.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Did you get your phone fixed?? If so what did you do?? Im having the same issues with my Blu 7.0
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Sim kit not in stole
Update (12/15/2015)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Here is a solution..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I had the same problem and i had to send it in. no reset would work. good luck
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
amanda 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 22
전체 시간: 3,135
