"unfortunately Lenovo Launcher has stopped working"
My A3300 tablet was put on charging. it showed "lenovo launcher has stopped working" and then it turned off.now it does not turn on. please help!!
좋은 질문 입니까?
좋은 질문 입니까?
Assuming this is an android tablet.... I would say that your software has been corrupted. Try doing a hard reset here:
http://support.lenovo.com/us/en/videos/v...
Hopefully this helps you out! Let me know if it doesn't work for you.
해당 답변은 도움이 되었습니까?
My Lenovo Tab 2 A7-30 has the same problem of "unfortunately lenovo launcher had stop" maybe this is because i tried to disable some of the apps to free some space for the RAM to work faster.....do i need to tried ur link above sir? PLEASE HELP ME.
Thank you in advance.
Check this video this will resolve this issue. I resolved by following this video only
해당 답변은 도움이 되었습니까?
1- open setting and open apps option
2- open all running apps
3- search lenevo launcher and clear the data and launch again
4- reboot your device
5 - follow this step i think your problem may be fixed up.
THANKU
해당 답변은 도움이 되었습니까?
It is impossible to get into the tablet with this failure!
3-open -Disabled menu
4 - enable theme app
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 9
30일 전: 39
전체 시간: 34,995
Thank you for your work
Elena 의
I am also faceing same problem
Sachin M 의
My mob k3 note I face same problem
Ashwini Pandit 의
Kindly help me how to solve my hp problem..
'lenovo launcher is not responding'
i have tried many times to restart my hp but end up my hp still can't function normally.
yonyoyo91 의
i have the same problem. I tried to disable some of the apps to free some spaces for the RAM to work faster. Then, this shows on my screen (Lenovo Tab2 A7-30) "Unfortunately lenovo launcher had stop" ....everytime i tap OK, it comes pops up again. I tried to reboot my lenovo tab, then on the box for the password, my keyboard isn't appearing anymore so i cannot key in my password (combination of letters and numbers). What should i do now? Please help me.
Thank you very much in advance!!
egayvicente2014 의
댓글 12개 더보기
