주요 콘텐츠로 건너뛰기
모델 A1347과 2.4 또는 2.66 GHz Core 2 Duo 프로세서.
76 질문 전체 보기
What is this loose part which was rattling in my Mac mini?
My Mac mini was rattling with a loose part. I used the guide to open it up and found the culprit. I don't know where it goes. It is small like the size of a safety pin and 28mm in length and 5mm width and is metallic with two legs widening out and a flat headed top bending up like a contact. Please help.
It looks a bit like an led component without the LED.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 2개
I've uploaded a photo on my Facebook page
It's also my avatar picture. Please help.
댓글 달기
답변 2개
선택된 답변
While hard to see I think you found the power supply clip. Here's a better image of it and where it's located: Power Supply clip.
Follow this IFIXIT guide to get to it: Mac Mini Mid 2010 Power Supply Replacement. You'll need to get to Step 22 in taking the mini apart, then reverse from there.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Brilliant thank you
댓글 달기
That part holds the female Power Adapter in place inside of the Mac Mini. Technically it just locks it in place as the adapter is held in place by tension.
It's really a not needed part.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
shamim1980 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 313
