주요 콘텐츠로 건너뛰기
모델 A1312 / Mid 2010 / 3.2 GHz Core i3 또는 2.8 & 3.6 GHz Core i5 또는 2.93 GHz Core i7, ID iMac11,3
383 질문 전체 보기
Upgrade to Bluetooth LE
With new features like Continuity and Handoff, I'm interested in upgrading my bluetooth board in my mid-2010 27" iMac to Bluetooth LE. I've seen a couple Mac forums that it has worked but they never mentioned the part or where they ordered it. Any ideas?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 2개
가장 유용한 답변
Hi - for the hardware hack, which will also give you Wi-Fi ac & will work through OS updates, you need plural parts, which are most economically sourced separately via Ebay; a certain amount of soldering is required.
Needed:
1: part 653-0014 = Broadcom BCM94360CD Wireless ac/Bluetooth 4/LE card. Around $30 via Ebay.
2: Adapter to fit above card [proprietory Apple interface] into a mini-PCIe slot, as found in your 2010 iMac for the existing wireless card - this adapter is often described as: "mini pcie adapter for BCM94360CD" and is now available, much improved, in a v3 hardware version. $10-ish via Ebay. Make sure you obtain v3 and that it comes with its cables.
3: Aerial adapter/extension to connect existing bluetooth aerial to BCM94360CD - this is tricky to source and is often described as: "U.FL male to U.FL female pigtail cable" you'll need one of around 2'/60cm. "U.FL" [connector type] may be called: "IPX" - you can pay as little as a couple of dollars [from China]: mine came as their part: OL-2198 from: onelinkmore.com
For full Wi-Fi function/performance you will want a third U.FL aerial - of around 18" - for the extra channel used by Wireless ac - these are easy to source.
On the 2009/2010 27" iMac, you need to provide D- and D+ signals/voltage from the wiring to the old bluetooth module [which you remove] to the adaptor card - the v3 model I sourced came with a plug-in cable for this, with the far end tinned and ready-to-solder.
Very good relevant images are available from a long macrumors forum thread [focused on the 2011 model iMac] in this post . . . I do not believe with a 2010 model 27" iMac that you need to provide the +3.3v power to the little pads provided for this purpose on the v3 board [to enable bluetooth function if you run off Wi-Fi from inside OSX]; but instructions are provided in the above thread if you sensibly want to take a belt-and-braces approach..
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Here's the best site on getting your answers: Continuity-Activation-Tool.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Ben 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 21
30일 전: 137
전체 시간: 1,808
