주요 콘텐츠로 건너뛰기
Model number NX785QC8G, released in 2014. RK3188 Quad core ARM Cortex A9/1.6GHz Processor, 1GB DDR RAM.
95 질문 전체 보기
Why is my battery not holding a charge?
After a full charge, the device will only stay on for an hour or two.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 11
댓글 1개
my nextbook wont comeon at all
댓글 달기
답변 4개
가장 유용한 답변
Be sure you are using the charger that was provided from the manufacturer. Generic chargers tend not to charge the device properly and may kill the battery cells.
If you are using the appropriate charger, and your nextbook is still not holding a charge, it is likely that your battery is dead and you will need to buy a replacement.
해당 답변은 도움이 되었습니까?
점수 8
댓글 4개:
So what battery do we buy & where are the guides on how to do this ?
I have the same problem, I need a new battery.
please give me something to do
Charger will not charge battery give help on what to do
Well we have to use a 5 volt battery charger what we do then
댓글 달기
Well we have to use a 5 volt batterywhat do we do then
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
How old is the battery?
Over time, rechargeable batteries lose their ability to hold a charge.
It might just be time to replace the battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Where done I get a battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Zeke 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 5
전체 시간: 2,759
