주요 콘텐츠로 건너뛰기
2011년 하반기 모델, A1278 / 2.4 GHz i5 또는 2.8GHz i7 프로세서.
591 질문 전체 보기
Will the 2010 MBPro Screen fit a 2011 MacBook?
I need to replace the display on my Late-2011 macbook, and both time and money are at a premium. I've found an affordable example which will arrive in good time but it's from the 2010 model MacBook, and mine's the late 2011.
Will this screen fit, and work?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I got around this problem by taking the glass from the 2010 keeping the 2011 assembly painful long process but works .
댓글 달기
답변 1개
선택된 답변
LCD, yes.
Full assembly, no.
2008 A1278 model uses an LCD assembly with the sleep magnet on the other side than the 2009/2010/2011.
2009 assembly and 2010 assembly are same thing, but wifi wire is 1 or 2mm shorter on one vs. the other.
2011/2012 assembly use different webcam, different webcam cable. Also these do not have wifi card in the lid, and they use a different wifi antenna which will not fit in the clutch cover.
So LCD, yes. Glass, yes. Entire ASSEMBLY, no.
해당 답변은 도움이 되었습니까?
점수 6
댓글 달기
귀하의 답변을 추가하세요
Alex 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 3,230
