주요 콘텐츠로 건너뛰기
Released in November 2012, the GoPro HERO3 is a Wi-Fi capable, 4K resolution digital camcorder.
Charge point broken in Hero 3
Where the cable goes into charge, it looks like the pin connector inside the Hero 3 has broken off and missing.
I only noticed it after daughter has had it for past 6 months!
How do you replace it? Do you have to replace the motherboard?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hi Mark,
Go through this teardown, pull a picture showing the broken connector, and post it here.
If however, it is the mini-USB charging port like you described, you'll need to replace it using solid soldering skills, the right tools, and of course the right replacement part. No need to replace the whole board. My advice in this case, if you lack the pre-requisites, is to have a specialized tech handle the repair, or take it to a GoPro reseller and have a shot at warranty coverage.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
Mark 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 15
전체 시간: 1,078
