주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Macintosh Classic은 1990년부터 1992년까지 Apple Computer, Inc.에서 생산한 개인용 컴퓨터입니다.
Transfer data from old SCSI hard drive
I pulled a SCSI hard drive from a dead Macintosh II desktop computer and would like to transfer the data to another more modern computer. Since I only want to do this one time I need an inexpensive solution to adapt the SCSI hard drive to either USB or Firewire. I could also hook up to an old PowerBook G3 to perform the transfer.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 6개
Hello,
I have this problem, too.
I have a Mac Classic of the year 1992 and it works no more because there is rust on the mainboard (it was stocked since years in a rather humid environment).
I have succeeded in opening and extracting the HDD, a Quantum ProDrive LPS (there is also an Apple label: Hard Disk 40SC) with 50 pin SCSI connection.
I have also an iMac (that one in form of a half sphere) that is still working and has already USB, as well as Windows PCs.
How may I read the disc?
Only on Mac or also on Windows?
Best regards
F. J.
You'll need a Mac to use the files, but some data files are transferable to a Windows system (i.e. MS Word, MS Excel, Adobe PDF ...) or a newer Mac OS-X based system.
So if you don't have a Mac you can use a Windows system which also has the needed software to read Mac drives: 4 Ways To Read A Mac Formatted Drive In Windows. Don't forget you still need the needed SCSI connection in your Windows PC to connect the drive.
You could even transfer your data to a more compatible drive for your Mac using the Windows system if you don't have a means to connect the SCSI drive to your Mac. Don't forget this older Mac system used OS-9 so the Mac you are planning on using here will need an older OS-X (Snow Leopard 10.6) to open the OS-9 Apps and its data.
Hi,
Thank You for Your answer.
The iMac has as well the OS 9 as an early Os X.
There is mainly one file I'm interested in: the database file of a geneology program.
If I succeed in retreiving it, the whole work will not be done: I'll need a program that can read the file.
Quote: "Don't forget you still need the needed SCSI connection in your Windows PC to connect the drive."
I planned to use an adapter from SCSI to USB. Do You think that it could work? I could use it with the iMac, or if it doesn't work for some reason, with Windows.
Sadly, I don't have any experience with these SCSI to USB converters. What can I say, give it a try ;-} Please let us know if it worked!
Ok
Does someone else have an idea about this challenge?
댓글 1개 더보기
댓글 달기
답변 2개
가장 유용한 답변
If you have a PowerBook with SCSI (pre firewire) and you can get the drive to work with that (probably OS 9 only) then you should be able to copy the contents to the PowerBook, then to a more modern format. It's probably only a couple of megabytes anyway. You are also facing the problem "what am I going to use to open these ancient files?"
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Thats the big question--will the data be available to modern software? + Ralph
The data, documents, music, movies, should have no problems moving. Of course the System 9 programs will not work. Word docs should import as well as most Adobe doc. Appleworks does have some problems with combined documents going into Pages.
Thanks for the help. I am getting closer to solving the problem by moving the drive to an old external hard drive. Now I just need a cable to the computer. The documents are Word or Excel so that shouldn't be a problem.
댓글 달기
Use a SCSI to USB adapter. Here's a link on how to do it:
http://www.topbits.com/how-to-connect-sc...
이 답변이 도움이 되었나요?
점수 5
댓글 1개:
Nice find + Ralph
댓글 달기
답변을 추가하세요
Roy 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 27
전체 시간: 17,983
