주요 콘텐츠로 건너뛰기
2011년 10월 24일 출시 / 2.2, 2.4, 또는 2.5 GHz 쿼드-코어 Intel Core i7 프로세서
405 질문 전체 보기
Late 2011 logic board in early 2011 unibody?
Didn't see this specific question answered. Looks like my video card died in my early 2011 MBP. Looking for a replacement logic board, looks like the slightly more powerful late 2011 logic boards are cheaper.
Given, their cheaper and with a bit more power; can I use a late 2011 logic board in an early 2011 case?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 3개
Can you give us the last four digits of your serial number so we can correctly identify which you exact model is.
Last 4 are: DRJC
It's an i7 2ghz and the new logic board is an i7 2.4 or 2.5. The early 2.0's cost more than the later models so, figure if it's cheaper and gives a little boost; seems like a better deal.
댓글 달기
답변 2개
선택된 답변
If you absolutely want to go ahead with the terrible idea of putting an 820-3330 board into a machine that originally had an 820-2915, yes, it will fit. You will just need a lot of tape to hold the LVDS cable into the LCD connector on the motherboard, the latch is different on 2012 models and will not fit 2011 boards. So tape is necessary. Otherwise, everything else fits - battery, keyboard, trackpad, hard drive cable, webcam cable, wifi cable, battery indicator, speaker, are all the same.
This is a really crappy solution considering you will be paying $650 for a jerry rigged setup that is two processor generations behind. I would call this a complete waste of money. Let's move on to a real solution.
Step 1 is to get Apple to fix this $@$* for free. https://www.apple.com/support/macbookpro...
Step 2 is to get it back and run GPUtest on it until it dies again. Furmark with max settings. http://www.geeks3d.com/gputest/
Rinse & repeat until they're tired of seeing you, and then say you want something that works. Gosh, you're willing to PAY, but you just need something that will work. Be nice about it so they feel bad for you. They'll cave and give you a Retina with iris graphics - if you complain hardcore, you'll get one with NVIDIA discrete. Iris still kicks the $@$* out of that AMD chip so you'll be good, many find it's not worth it to ##&&% to get the NVIDIA - lots of escalating and time wasted for minimal return on investment.
Some will say this is unethical. I say it's unethical to sell a $2700 machine that dies for no reason and then to ignore your customers. When you see how easy it is to kill the one they give you back with Furmark you'll feel the same way - this is a really BAD laptop and they put billions in the bank selling this aluminum cat bed heater to the American public for $2000+.
This repair program only lasts until January 2016, and you bet your @%^ it will fail days outside that program. So do what you have to to get Apple to give you a proper machine that doesn't die watching YouTube videos before you're SOL.
Or you could spend $650 to put a used ivy bridge board from eBay with no warranty, that's slower than the retina in your machine... your choice.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks Louis. I miss read the details of the extended support and thought my MBP was out of support for this issue. I went to the Apple Store and they are fixing the GPU/logic board. I'll give the rest of your solution a try too!
댓글 달기
가장 유용한 답변
Here is a list of systems you should be able to swap parts around: MacBookPro8,2.
Here is what your system's CPU offers from EveryMac web site:
  • This model is powered by a "Quad-Core" 32 nm, 64-bit Intel Mobile Core i7 "Sandy Bridge" (I7-2635QM) processor.
Here's the specs on the CPU on the this system: MacBook Pro 15" 2.4 GHz i7 (Late 2011) again from EveryMac web site:
  • This model is powered by a "Quad-Core" 32 nm, 64-bit Intel Mobile Core i7 "Sandy Bridge" (I7-2760QM) processor.
I don't see any reason why it wouldn't work. Just remember the clock rate while faster is not as big a jump to offer much change in performance. So don't make the point four (.4) be the deciding factor if you can get a 2.0 GHz board for less.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thanks Dan. Seems like a simple swap so, if I pull the trigger I'll post my success or failure here.
Hi, did you swap you logic board? If yes, did it work? Same situation here...
댓글 달기
귀하의 답변을 추가하세요
glenn 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 5
전체 시간: 1,951
