주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
Camera flash not working
My Iphone 5s Camera flash doesnt work, its supposed to have two leds, the yellow and the white, the white doesnt work so i press the flashlight icon in control center and it gets highlighted as working but nothing happens, when i switch to video mode it doesnt light up, i notice the LED or bulb doesnt work because when I take a picture with flash ON the yellow light flashes but theres no flash on pictures, so Its not a software problem, please tell me how to fix this problem and the replacement i need to buy, thank you.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 10
댓글 3개
my device camera as well as flash not working . I there any way to fix it
it supposed to be yellow and white flash but my iphone 5s flash is just white which still works
My flash went out as well how can I solve this problem
댓글 달기
답변 6개
선택된 해법
You need to buy a power volume flex as the led light is located on that
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
This was the solution to my problem thank you very much!
댓글 달기
I am also facing this Problem. My volume down button is also not working.. First the volume button fails then Flash of the camera. Amber led working but white one is not!!
이 답변이 도움이 되었나요?
점수 1
댓글 5개:
Its the power volume flex, that is involved in volume has the led from flash lock button etc, this piece is cheap and replaced in 15 min!! Good luck!!
was it safe? I mean repairing? cause I am afraid that something other will not mess up
Well, this piece involves a lot of the phones features but just follow the video and i guess you'll be fine, but if youre not the the "i'll repair it myself person look for someone to fix it for you, obviously experienced.
can u post a video?
Sania nadeem,
Finally I fixed this problem to replace the (power volume and flash light) single flex...
댓글 달기
Here you can get a power volume flex http://www.iboxfix.com/flex-ribbon-c-164...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
same to sania
이 답변이 도움이 되었나요?
점수 0
댓글 달기
my iphone 6 flashlight is working on Video and flashlight but When I taking a picture with flash, white led is working but Amber led is not working.. because of that picture with flash is being dark !
Do you have any idea What is the solution ?
thank you
이 답변이 도움이 되었나요?
점수 0
댓글 달기
i;gt9 6tp/y8 g;p.gilbuj,gbulihilihh
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alex 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 20
전체 시간: 24,676
