주요 콘텐츠로 건너뛰기
Samsung의 5-세대 Android-기반 Galaxy 스마트폰은 2014년 4월 11일에 출시되었습니다. 이 휴대폰은 지문 스캐너, 최신 카메라, 대형 화면 및 방수 기능이 개선되었습니다. 네 가지 색상으로 제공됩니다; 검정, 파랑, 흰색 및 구리.
577 질문 전체 보기
Same screen for Samsung Galaxy S5 Plus G901F?
I was wondering if someone knows if the display assembly for a Samsung Galaxy S5 G900 is compatible with the model Samsung Galaxy S5 Plus G901F. The only thing that changed from the S5 to the S5 Plus version were some chips so I'm wondering if i can use one on it because I find no other assemblies.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 5개
I tried a cheap g900 screen off ebay and it caused my phone to bootloop. not sure if the display was faulty or if the g900 displays simply don't work on the g901f
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
hello ,it looks the same but is not the display from normal s5 g900f is not compatible with th s5 901f Plus ! is different hardware ! is the same from s2 to s2 plus ! not compatibel is not work ! you must buy for samsung galaxy s5 plus g901f ! and the hardware is different to ! ok if you google it looks like the same but the display from s5 900f is different ! the other problem is that most of the seller write the screen sale name and that's basically wrong but easier for customers ! if you buy thenn buy for the right phone !
regards,
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
This is an odd one. Several people have reported that a 901 screen in a 900 phone and vice versa, wil cause a boot loop. However, I've found this not to be the case, both with genuine screens pulled from phones and with cheap chinese ones. It seems that at some point, software on phones and hardware on screens 'met in the middle'.
Sorry, I couldn't be more specific
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi. Are You sure that cheap chinese IPS from G900F will work with G901F?
댓글 달기
With one of these Chinese IPS displays (advertised as being for SM-G900F) I had a bootloop with the G901F.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Not the same,not usable.dont bye,fore the 901,back is bras,and thiner,900 back is like foame,and thicker.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Alain Wittwer 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 4
전체 시간: 1,035
