주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Home Button stops working after bettery replacement.
After battery replacement, my iPhone 5's home button is not working at all, not even if I press really hard.
I've had several topics and mostly people say the 3 chips next to the sim card might be knocked off. I checked and those chips of my phone are still at there with their black boxes.
Anyone knows what else I should check ?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 1개:
When removing the battery did you pry on between the logic board and the battery? If yes, then you could have caused some logic board damage. Also take a look at your home button flex you could have damaged it.
댓글 달기
답변 1개
When you open the 5s, you need to remove a tiny metal cover carefully, then carefully detach the home button flex from the plug at the base of the battery. When removing the battery, if you weren't able to use the white ribbons to remove the adhesive, it's really tough to un-stick. Prying the battery up may cause you to lean on, bend, or break delicate grounds or components.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
concuagia 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 127
