주요 콘텐츠로 건너뛰기
2008년 10월 출시 / 2.4, 2.53, 2.66, 2.8 또는 2.93 GHz Core 2 Duo 프로세서
376 질문 전체 보기
WD MyPassport external hard drive won't mount to my MacBook Pro
When I plug my external hard drive into my MacBook it flashes its white light and begins to stay solid, but doesn't show up on my desktop. I opened up disk utility and it said it was not mounted. I tried to repair the disk, but I got an error: File system verify or repair failed. Is there anything I can do?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 4
댓글 달기
답변 4개
가장 유용한 답변
Most of these drives can be changed to another external enclosure. I would get one that is self powered rather than USB pot powered.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
So I should get a self powered external, and then back up my external that I have now on the self powered one?
You can try that or just get an external enclosure, transfer the hard drive and see if it works. That failing, drop a new drive in the new and/or old enclosures.
댓글 달기
Hi, i have the exact same problem on a wd my passport 2tb drive formatted in hfs + (for mac). The wierd thing is that it mounts on windows 7 via bootcamp and paragon hfs + for windows ... So i think the problem comes from os x (yosemite for me) and i dont wanna reinstall everything.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I plugged the WD My Passport Ultra into my Window 8.* laptop and pulled up Windows Disk Management to ensure I had exFAT formatting and that the partition was ACTIVE. Corrected both, did a safe eject and plugged it back into the MacBook Pro and OSX 10.10 now mounts the drive. It works, try it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
use disk utility. erase the drive
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Bryan Harris 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 14
30일 전: 23
전체 시간: 7,117
