주요 콘텐츠로 건너뛰기
The Canon Powershot A590 IS is an 8 megapixel digital point-and-shoot camera with a 4x optical zoom and a 2.5 inch LCD screen.
20 질문 전체 보기
Black Spot on pictures
1/2" square black image appears on Lcd Monitor and in pictures. It looks like a piece of dirt on the lens but it will not wipe off, it must be on the inside.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개
It looks like you solved your own problem right there in your question, they just confirmed your solution. :)
댓글 달기
답변 3개
선택된 해법
We had an issue like this with one of the cameras here. Sure enough, as Majesty has said, it was a small speck of dirt on the sensor. Compressed air is a fine solution. They also make a cleaning solution for cameras for just this purpose as well.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
가장 유용한 답변
I would carefully open the camera up and clean the insides with compressed air. You might have dirt or other small debris on the sensor. Don not try to wipe the lens, most likely the debris is inside of the camera.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
yes
clean the sensor(CCD)
10000% clear ur fault
i have clear this fault many time
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Keep up the repair solutions, but please do not post contact information to advertise your personal business. Thanks!
댓글 달기
답변을 추가하세요
Ron Skelly 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 5,020
