주요 콘텐츠로 건너뛰기
LG가 제조한 스마트워치 LG G Watch R은 스마트폰의 많은 기능과 원형 P-OLED 화면을 사용합니다.
26 질문 전체 보기
Do this device have a wifi antenna?
Does the G Watch R have a wifi antenna? Does it share the Bluetooth antenna?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 5개
가장 유용한 답변
It looks like it doesn't per LG's specs sheet: LG W110-G Watch-R
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Quote from Ars Technica: "The reason the G Watch and G Watch R aren't getting updated isn't because of the Wi-Fi chip, it's because they lack Wi-Fi antennas. LG just didn't pack them into the G Watch and G Watch R."
댓글 달기
it has a Broadcom BCM4343WKUBG chip
the chip is wifi 802.11/bt 4.1 LE
it only needs 1 antenna to work so LG could simply be lying about "not being able to use wifi on the GWR".
ITS CAPABLE...
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
You are right it has the chip, so it could, its just not wired up.
댓글 달기
The spec sheet on the moto 360 doesn't list it either. Wifi capability has never been mentioned prior to the 5.1.1 announcement. connectivity only lists Bluetooth4.0. http://moto360.motorola.com/?gclid=CjwKE...
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
There's some answers:https://plus.google.com/1046008496142995...
Spread the word.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
So this may have been resolved long ago, but here's the deal. The watch has a WiFi ship, but it wasn't enabled at first. They needed to re-certify it once the software could support it.
I can confirm that later software updates enabled the WiFi chip on my G watch R, and it does work!
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
James Kemble 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 1
전체 시간: 1,375
