주요 콘텐츠로 건너뛰기
Apple의 iBook 노트북 라인은 소비자 및 교육 시장을 겨냥한 제품이었습니다. iBook 라인은 iBook G3 Clamshell, G3 12", G3 14", G4 12", 그리고 G4 14"로 구성되어 있습니다.
832 질문 전체 보기
Why does my iBook freeze?
Mac 0S 10.4
1.07GHZ G4
256MB Internal Memroy
30GIG hard drive
1. When im playing chess or online, computer freezes.
2. I downloaded the monitor temperator, and below are 3 temperature stages that i ran while playing chess.
Try 1
Try 1 Try2 Try3
Graphics Processor Dies 1)35.2 2)34.5 3)40.8
Power Supply : 1)25.0 2)22.8 3)28.0
Processor Bottom 1)37.2 2)31.8 3)38.5
I have the notebook open and i do not see the fan spinning at all,
i added my own 12volt fan and turn it on and notice when i put
the fan the graphics and processor have temperatures of 25 each.
Anyone have this problem??? Computer just freezes, but does not shut down..
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 7개
선택된 답변
You might want to remove the extended RAM module and Airport, and reset the PMU and PRAM. This can sometimes make a difference. Beyond that, it's likely a flaky board, since bad hard drives rarely cause the computer to freeze up. Is the light on the AC adapter flickering or going between different colors by chance? Sometimes when the DC-in plug is bad it can be very sensitive, and a computer without working battery will die or freeze just from being bumped lightly. Good luck!
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
You're pushing that iBook pretty hard running 10.4 with 256MB RAM
That JUST meets minimum requirements.
If you have an almost full HD you could be running into memory swap issues. You need at least 6GIG hd free for VM and temp files.
I'd Max the RAM on that sucker... If you can't do that kill every background/startup app I didn't need (check what launches at login). I Would turn the computer off when not in use (clear Memory fragmentation).
Good Luck,
N.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Any chance the freezing is related to the specific chess program you're using rather than overheating? Does the computer freeze when using other programs or doing other things? You mention "online," but I couldn't tell if that was from general surfing or if maybe your chess program is online.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
The DC adapter is fine, and when i go on youtube it freezes,
has anyone tried the burning candle on the chip? i heard of
the blow torch , resoldering all the solder balls under the chip
with the white saint candle.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have MAC OS 10.2, i might
throw that in instead and
replace the OS, i'll let you
all know what happened.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I have an iBook 14" 1.42.ghs. with 512mb ram, i expand it at ighz,and sudenly, is freeze, restart, and the memory goes to 512mhz.what can i do? tank you for your help
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
== Is the RAM correct? == e.g. PC2700 (333MHz) DDR SDRAM and seated correctly?
Is the ram known to be good?
When you say "goes to 512MB" in system profiler=>memory does it see the new ram, or are you only looking at "about this mac"?
N.
댓글 달기
Hi
Have you resolved this situation?
Regards
Chris
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
el guy 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 1,257
