주요 콘텐츠로 건너뛰기
집에있는 영화, 음악, 멀티미디어. 자사의 안내서를 사용하여 서라운드 사운드 A/V 수신기 또는 일반 스테레오 수신기, 전력 증폭기, 프리 앰프, 스피커 및 iPod/블루투스 스피커 시스템에 이르는 홈 엔터테인먼트 장치를 수리하십시오.
4606 질문 전체 보기
Harman Kardon SoundStick power supply and pin outs?
I have a Harman Kardon SoundStick without power supply. Looks like Harman Kardon sells the replacement power supply, but I want to know the pin outs so that I may be able to power it up with power supplies I have.
Can someone tell me the pin outs of the connector of power supply?
If you have one, please!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 5개
There were several versions of the HK SoundSticks with different power supplies. The first ones plugged into the sound port and later went to USB. Which ones do you have?
It says "SoundSticks", has a USB. It also says 16V, 1.5A.
I noticed you never got an answer to this. Are you still having this problem?'
It's still sitting in my attic, and would like to power it up.
My HK-ii need a new power adapter. It went lost when moving house. I am in Sydney.
댓글 달기
답변 5개
선택된 답변
I think I found the answer, in two ways.
I got my hands on the actual power supply, and confirmed the pin out.
Also, the plug is Hosiden TCP8927-53, Kycon KPP-3P, as found in Wikipedia's DC_Connector.
You can find the pin out in
http://www.bematech.com/support/download...
I confirmed that the pin out in above matches with the actual power supply, so I am good to go.
I can probably get the Kycon KPPX-3P from Mouser, and a 16V power supply, which I plan to use a laptop power supply I can get cheap.
-- Tai
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
+ very nice work, it would be great if you could take some photos and do a small manual on this so others can learn from your efforts.
Top answer, thank you!
thank you very very many times!!!
Hi, thank you for the answer. The link with pins is not working anymore. Do you have another link?
댓글 달기
I built a replacement power supply for a Harman Kardon SoundStick by finding a laptop supply of approximately 35W on eBay. I bought an IBM Lenovo ThinkPad 16V 2.2A Laptop AC Power Supply Charger 85G6734 for £6.99 as it seemed about right and was a fair price (though then had to additionally by a clover style power chord for another £3 so check on eBay that you're buying the whole thing or that you have a power chord that is the same style).
I cut the end off of the power supply behind the choke as this was getting in the way.
Next fit a new plug - the Maplin 3 pin power DIN plug assembly (their code: N83KT £1.49) is the one you want. It's a bit complicated to assemble (and quite amazing for less than £2) but after a few tries it fits together well. There is some soldering required so you'll need to buy or borrow an iron and solder. I hadn't done any soldering for over 20 years - if you concentrate on melting the solder onto the joint to form a bond and don't worry about doing anything else you should be fine.
The pin connections are as shown here: http://www.bematech.com/support/download.... On the Lenovo power supply the sheathed centre wire is the +ve (pin B) and the outer stranded wire the -ve (pin A).
Good luck.
해당 답변은 도움이 되었습니까?
점수 2
댓글 달기
The pdf is available through the Internet Archive.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
the HK parts supplier in the UK (multicare.org.uk) are asking £34+VAT for a new one, so this appreciated :)
댓글 달기
I found what polarity it is tried my luck since the site dont work its iSub 2000.The red marker is positive and blue is negative. Used paper clip and labalatory power supply to power it up.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
chrager from soundsticks 3
has the pinout on the right
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Naoyuki Tai 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 3
7일 전: 13
30일 전: 62
전체 시간: 19,540
