The trick to all this would be to get this big chip on the bottom right to be reworked on with a professional rework station , i read these instruction on the link you previously provided me !
This post is within this following link :
http://forums.macnn.com/103/ipod-iphone-...
posted by warnergt
My hypothesis was that there was a bad solder joint on that component. That's why cooling it (compression/expansion) or pressure on it made the iPod work. So the solution would be to reflow the solder enough to reestablish a solid connection.
I actually performed this fix with the iPod powered on and running. Repeat this exercise at your own risk. I used a Panavise to hold the hard drive and metal backplate out of my way. I used the wooden end of a Q-tip style dowel to put pressure on the device. I used a heat gun to heat the device and the solder around it. While placing pressure on the device -- more specifically, the left edge of the device which seemed more sensitive during my probing -- I heated the left area of the device with a heat gun. These heat guns get very hot; there is a fine line between just enough heat and too much heat. I heated it up for just a short period (maybe 5-10 seconds). I started to smell something (good signal to stop [or you went too far]) and removed the heat while still maintaining as much pressure as I could get on the device. I allowed the device and solder to cool for about 20-30 seconds while maintaining pressure. I even blew on it some to speed the process.
The whole time I did this, I was listening to it play with my earbuds. It continued to play. It's still playing now. I hope it continues to play for a long time.
Could you give some description of what happened to the device? Is it brand new and doesn't work out of the box, was it dropped, did it take water damage, or did it slowly stop working, etc?
Taylor Arnicar 의
First thing - I'm assuming you tried swapping out to a different pair of headphones, yes?
Taylor Arnicar 의
of course. I bought a new jack for the ipod online and followed the step by step instructions from this site.
Matt 의
Hehe, ok. Just had to check. :P Does it produce any sound when it's docked?
Taylor Arnicar 의
I tried it but it says very low battery. It wont turn on in the player but if I hook it up to a wall charger it resets and looks like it has full power.
Matt 의
